查看: 55121|回复: 68
汽车ecu编程器xprog(官网公开的资料)
发表于 2012-5-12 23:40:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
汽车ecu编程器xprog(官网公开的资料),这个大家制作该放心了
当然这个是串口版的,usb版的那个可没公开
一下是原文:
TheXPROG supports programming ofMotorola 68HC05xx,68HC08xx, 68HC11xx microcontrollers internal EEPROM and serial EEPROM's- most used programmable device in car radios, automotive computers(dashboards, AIRBAG, immobilizers), and industrial products.
Motorolamicrocontrollers(on-board programming):
MC68HC11A8,MC68HC11E9, MC68HC711E9, MC68HC811E2, MC68HC11E20, MC68HC11G5,MC68HC711G5, MC68HC11N4, MC68HC11F1, MC68HC11PH8, MC68HC711PH8,MC68HC11PA8, MC68HC711PA8, MC68HC11K4, MC68HC711K4, MC68HC11KA4,MC68HC711KA4, MC68HC11L6, MC68HC711L6,MC68HC11P2, MC68HC11F1
MC68HC11PH8(0H30RQ=614kHz) , MC68HC11PH8(3D64J Q=614kHz) , MC68HC11P2(0G10V Q=614kHz) ,MC68HC11P2(1E53M Q=614kHz) , MC68HC11P2(3E74J Q=614kHz) ,MC68HC11EA9(2D47J) , MC68HC11EA9(1D47J) , MC68HC11EA9,MC68HC05B6/16/32, MC68HC705B16/16N/32, MC68HC05X16/32,C68HC05B32 (newtype from Audi CHORUS),MC68HC05H12(0H57A) , MC68HC05E6(0G72G) ,MC68HC05E6(0F82B) , MC68HC05X32(0D69J;1H52A) , MC68HC05X32(0D53J) ,MC68HC08AZ32 , C68HC08AZ32(0J66D) , MC68HC08AS60 , MC68HC08AZ60 ,MC68HC08AZ60A ,
SerialEEPROM:
AT93C46,AT93C46A, AT93C56, AT93C57, AT93C66, AT59C11, AT59C12, AT59C13,CAT24C01, CAT24WC01, CAT24C02, CAT24WC02, CAT24C04, CAT24WC04,CAT24C08, CAT24WC08, CAT24C16, CAT24WC16, CAT24C32, CAT24WC32,CAT24C64, CAT24WC64, CAT64LC10, CAT64LC20, CAT64LC30, CAT93C46,CAT93C46A, CAT93C56, CAT93C57, CAT93C66, CAT93C66A, CAT93C86, 24C01A,24LC01B, 24C02A, 24LC02B, 24C04A, 24LC04B, 24C08A, 24LC08B, 24C16A,24LC16B, 24C32A, 24LC32B, 85C72, 85C82, 85C92, 93C06, 93C46, 93LCS46,93LC46B, 93C56, 93LC56, 93C66, 93LC66, 93C76, 93LC76, 93C86, 93LC86,M6M80011P, M6M80021P, M6M80041P, NM93C06, NM93C46, NM93C14, NM93C56,NM93CS56, NM93C66, NM93CS66, NM93C86A, SDE2506, SDE2526, X24C00,X24C01, X2402, X2404, X2408, X24164, X24165, X2444, X24C44.
HardwareSpecifications :
Includehigh output current MPU.
External output for on-board device programming via universal XPROGconnector..
Serial port interface (up to 115K baud) works on (COM1, COM 2, COM3 orCOM4).
            FunctionSpecifications:
FileLoad / Save, Read, Write, Verify,Checksum, Security, Edit, Options Configuration.
ElectricalRequirements:
OperatingVoltage : +12-15V DC.
Power Consumption : 50 mA.
制作资料:
软件 DPD_V42setup.exe (4.73 MB, 下载次数: 1360)
原理图 Xprog_sch.pdf (26.6 KB, 下载次数: 100)
固件 pic16f84.zip (822 Bytes, 下载次数: 73)
使用手册 Instrukcja XPROG - pl.pdf (2.04 MB, 下载次数: 1282)
收藏收藏8 分享分享 支持支持 反对反对
沙发
发表于 2012-5-15 23:19:48 | 只看该作者
什么是ECU ?
板凳
 楼主| 发表于 2012-5-16 09:07:43 | 只看该作者
dglb 发表于 2012-5-15 23:19
什么是ECU ?
ECU(Electronic Control Unit)电子控制单元,又称“行车电脑”、“车载电脑”等。从用途上讲则是汽车专用微机控制器。它和普通的电脑一样,由微处理器(CPU)、存储器(ROM、、RAM)、输入/输出接口(I/O)、模数转换器(A/D)以及整形、驱动等大规模集成电路组成。用一句简单的话来形容就是“ECU就是汽车的大脑”。
地板
发表于 2012-5-16 20:21:24 | 只看该作者
其实就是一块单片机嘛 .
5#
发表于 2012-6-28 23:08:06 | 只看该作者
单片机,不简单,有很多盗版都不稳定
6#
 楼主| 发表于 2012-6-29 06:10:19 | 只看该作者
woodjay 发表于 2012-6-28 23:08
单片机,不简单,有很多盗版都不稳定
这个是官方的,肯定没问题的
7#
发表于 2012-6-29 10:56:23 | 只看该作者
很好,支持
8#
发表于 2012-6-29 21:49:05 | 只看该作者
感兴趣,不过要试试才知道
9#
发表于 2012-6-29 22:32:24 | 只看该作者
很好,研究一下
10#
发表于 2012-8-21 10:57:07 | 只看该作者
没事研究一下 很有用的
GMT+8, 2024-12-23 09:20 , 耗时 0.117640 秒, 25 个查询请求 , Gzip 开启.
