查看: 5742|回复: 1
AVR-Doper下载线
发表于 2011-5-5 11:09:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
AVR-DoperAVR-Doper is an STK500 compatible In-System Programmer (ISP) and High Voltage Serial Programmer (HVSP). It comes with a built-in USB to Serial adaptor to connect directly to USB.
Features
    HVSP allows using RESET pin for I/O, which is especially beneficial on 8 and 14 pin devices. Simple hardware which can be built on a single sided PCB. No special USB chips are needed. Compatible to Atmel’s STK500 with built-in USB to Serial converter. Adjustable ISP clock allows flashing of devices clocked at very low rate, e.g. 32 kHz. ISP clock can be lowered with a jumper (if the programmer software does not support setting the ISP clock). Second USB to Serial converter for processing debug output from the target. HVSP connector compatible to HVProg, another STK500 compatible programmer (see www.der-hammer.info/hvprog/index_en.htm). Uses USB power supply, no external supply required. Firmware can be compiled to run on metaboard hardware and USBasp hardware.
  • Open Source (including firmware and schematics).
原理图
制作相关资料
AVR-Doper.2008-11-27.tar.gz (456.21 KB, 下载次数: 11)
沙发
发表于 2012-6-15 20:29:13 | 只看该作者
哈哈,终于找到一个资料完整的了。
GMT+8, 2026-4-27 11:26 , 耗时 0.108210 秒, 22 个查询请求 , Gzip 开启.
