查看: 7825|回复: 1
Bus Blaster v2
发表于 2014-10-14 17:00:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
说实在的,这个也是不错的方案,可以参考下,原文:
Bus Blaster v2 design overview
Bus Blaster v2 is an experimental, high-speed JTAG debugger for ARM processors, FPGAs, CPLDs, flash, and more. Thanks to a reprogrammable buffer, a simple USB update makes Bus Blaster v2 compatible with many different  JTAG debugger types in the most popular open source software.
  • Based on FT2232H with high-speed USB 2.0
  • Buffered interface works with 3.3volt to 1.5volt targets
  • Reprogrammable buffer is compatible with multiple debugger types
  • Compatible with 'jtagkey', 'KT-link' programmer settings in OpenOCD, urJTAG, and more
  • Should support Serial Wire Debug when available
  • Mini-CPLD development board: self programmable, extra CPLD pins to header
  • Open source (CC-BY-SA)
Bus Blaster v3 is now available for $34.95. Bus Blaster v2 is available now for $34.95. Each unit is tested with a real JTAG target before it ships.
Read about the design below.
Overview
The Bus Blaster is used to program and debug devices with a JTAG interface like ARM processors, CPLDs, flash memory, and more.A FT2232H USB chip gives us two high-speed JTAG interfaces. The 16 pins of the primary interface are connected to a CoolRunner-II CPLD. The CPLD is a programmable buffer that translates between the FT2232H at 3.3volts, and a 1.5volt to 3.3volt target.
Many JTAG debuggers use the FT2232 chips, but they have slightly different buffers. The CPLD can be programmed to imitate many of them, so it works out of the box with our favorite open source debugging apps. Updates are done over USB using the second JTAG interface on the FT2232H.
This project was inspired by a forum post that linked to a Texas Instruments' XDS100 programmer. TI's design is essentially the same, but we moved the CPLD JTAG connection to the second JTAG interface for easier reprogramming. Bus Blaster v2 was developed in a public forum, and progress was documented on a wiki.
Hardware
Click for a full size schematic image. Schematic and PCB were designed with the freeware version of Cadsoft Eagle, download the latest project files from our Google Code project page.
FT2232H
The FT2232H is a powerful USB to serial communication chip. It has an MPSSE feature that provides a simple USB to JTAG converter (and UART, I2C, or SPI). Most DIY JTAG debuggers use this chip, as do many commercial models.
Bus Blaster v2 uses the 'H' version of the chip, the latest 3.3volt revision that supports JTAG adaptive clocking. The circuit is based on a reference design from the FT2232H datasheet.
Buffered interface
The buffer translates voltage levels between the FT2232H (3.3volts) and a JTAG device (1.5volts-3.3volts). The four main JTAG IO pins (TDI, TDO, TCK, TMS) are fixed on the FT2232, but the other reset and control pins vary among programmers.
Bus Blaster v2 is buffered by a programmable logic chip (CPLD) that can be updated to imitate many common buffer types. The CPLD is connected to the secondary JTAG interface on the FT2232, so uploading a new buffer type is done entirely from software over USB.
CPLD
An XC2C32A CoolRunner-II CPLD (IC9) is used for the buffer. These are the smallest available CPLDs from Xilinx, and they only cost around $1 in onesies.
The CPLD core requires a 1.8volt supply, which is conveniently available from the FT2232. The JTAG and IO pins are powered by a separate supply between 1.5 and 3.3volts. Each supply pin gets a 0.1uF capacitor.
This chip is perfect for voltage translation because the IO pins are divided into two groups that can operate from different power supplies. We connected one group to the FT2232 and the 3.3volt FT2232 power supply. The other group connects to the JTAG target, and operate from a 1.5volt to 3.3volt target supply.
You must connect the target power supply to the bufferThe buffer is powered by the target, 1.5volts to 3.3volts onlyPut a header on JP4 to power the target from the programmer. 3.3volts max 200mAThe buffer is NOT 5volt compatible.
We brought the extra CPLD pins to a header. The Bus Blaster v2 can also be used as a simple CoolRunner-II CPLD development board.
Buffer logic
New buffer logic is designed using simple schematic entry, Verilog, or VHDL, and the free ISE Webpack software from Xilinx.
Here are two examples of buffer logic to give you an idea how flexible the design can be.
JTAGkey compatible
The JTAGkey is probably the most commonly used buffer configuration among DIY FT2232-based JTAG programmers. It is compatible with OpenOCD, urJTAG, and more.
Program the Bus Blaster 2 with this buffer and it will work with most applications that support JTAGkey type debuggers.
KT-link compatible
OpenOCD and urJTAG will soon support new Serial Wire Debug and Serial Wire Viewer JTAG protocols via a KT-link type buffer.
Program the Bus Blaster 2 with this buffer and it can support SWD in OpenOCD and urJTAG. Special thanks to the developers of libswd for help implementing this buffer on the Bus Blaster.
Pinout
JTAG header pinout
pin Fixed FT2232 pin description direction
VTG
Voltage targetinput
TRST
Reset outputoutput
TDIADBUS1 JTAG data in to targetoutput
TMS ADBUS3 JTAG state machine updateoutput
TCK ADBUS0 JTAG clock in to targetoutput
RTCKADBUS7 System return clock input
TDOADBUS2JTAG data out from target input
TSRST
Bi-directional reset pin inout
DBGRQ
Debug request output
DBGACK
Debug acknowledge input
9 CPLD pins are brought to the 20pin JTAG header. The pins are labeled, but the CPLD buffer makes placement totally arbitrary.
Not all pins are supported by all buffers and/or applications
The VTG pin should be connected to the power supply of the device under test. The JTAG pin outputs will then work at the same voltage.
The target must generally supply power to the VTG pin!
The JTAG pins can also operate from the 3.3volt on-board power supply by placing a jumper on header JP4. In this configuration the VTG pin can supply up to 100mA @ 3.3volts to the test device.
PCB
We used the freeware version of Cadsoft Eagle to make the schematic and PCB. Download the latest designs and firmware from the project Google Code page.
Partslist
Click for a full size placement image.
partslist
PartQuantityValuePackage
C1-C7,C13-C2116100nFC805
C813.3uFSMC_A
C9,C10227pFC805
C11,C12,C2234.7uFSMC_A
IC11FT2232HLQFP64
IC2193LC46BSOIC8
IC31LD1117-3.3SOT223
IC91XC2C32A_VQ44_2VQ44
JP1-410.1" pin header1X0X
JTAG12x10 shrouded header (0.1”)PINHEAD_-_COPY_PINSHRD_PTH_2X10
L1,L22ferrite bead (800mA+)FB805
PWR1LEDCHIPLED_0805
R1112K 1%R805
R211KR805
R3,R4,R5310KR805
R612.2KR805
R1011KR805
USB1USB mini-B connectorCONN_USB_MINI-B
X1112MHz crystal4X6
The latest sources and distributors are in the master partlist. See something missing? Please let us know.
Taking it further
The reprogrammable buffer logic should future proof Bus Blaster v2. Already we were able to add Serial Wire Debug support by creating a new buffer implementation.
A minor revision in the next batch has a few minor changes:
  • Jumper JP4 moved to edge of PCB
  • LED and button connected to CPLD for demos
An eventual point revision is planned with:
  • 3.3volt over voltage protection for the CPLD
  • Serial resistors on the JTAG pins
v3 may use a 100pin CPLD to include support for SWV, another reduced pin-count JTAG protocol.
收藏收藏1 分享分享 支持支持 反对反对
沙发
发表于 2014-10-14 21:07:03 | 只看该作者
沙花,谢谢楼主分享。。
GMT+8, 2026-4-27 07:54 , 耗时 0.231541 秒, 25 个查询请求 , Gzip 开启.
