查看: 5901|回复: 2
[转载] 带显示屏可以脱机 ISP 的 USB HS 全驱动编程器 UprogHS 48
发表于 2014-11-13 19:25:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
  • Two operation modes: stand-alone and standard PC hosted (USB).
  • Interface with PC through USB port.
  • 48-pins powerful pindrivers.
  • No adapter required for any DIL devices.
  • Built-in keyboard and LCD display.
  • SmartMedia memory card to store data files and devices in stand-alone mode.
  • FPGA based microcontroller for very fast programming.
  • Build in interface for in-circuit programming (SPI, JTAG, Microwire, BDM, etc.)
  • Supports standard 5V and low voltage devices down to 1.8V.
  • Simple realization of GANG programmer.
  • Short programming and verification times.
  • EPROM/EEPROM simulator up to 128kB (512kB).
  • Universal digital IC tester.
  • Ulogic - logic analyser: 8 channels - 80Mhz, 16 ch. - 40MHz (option).
  • Adapter Creator feature allows to use many adapters from different providers.
  • Software for Windows Win98/ME/2000/NT/XP.
Dimensions: 12 x 21 x 5 cm
收藏收藏1 分享分享 支持支持 反对反对
沙发
发表于 2014-11-14 08:51:50 | 只看该作者
个人觉得布局不是很方便,要是把lcd放到操作面板附近更好点,放桌面操作的话看不到还得站起来,不是很人性化
板凳
发表于 2015-1-5 17:06:06 | 只看该作者
非常漂亮的烧写器
GMT+8, 2026-4-27 21:53 , 耗时 0.133538 秒, 20 个查询请求 , Gzip 开启.
