查看: 5254|回复: 0
[转载] XILINX FPGA 箝位二极管
发表于 2014-11-22 09:53:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Which pins do not have clamp diodes?
When clamp diodes are enabled (based on the I/O Standard), which pins do not have the clamps? Do the JTAG pins have clamp diodes?
Virtex and Spartan-II
On these devices, all I/O standards have an intrinsic diode between the I/O pad and ground that limits undershoot to greater than -1 V.
The LVCMOS 2.5V, LVTTL, and PCI 5V standards are all 5V-tolerant (both inputs and outputs) and do not have a pull-up clamp enabled.
Because configuration pins default to LVTTL, these only have pull-down clamp diodes enabled.
Virtex-E and Spartan-IIE
These devices are provided with a pull-up clamp diode between the I/O pad and VCCO that allows them to be 5V-tolerant and reduces overshoot.
The clamp diode is available with all I/O standards (including all configuration pins), excluding LVDS, LVPECL, GTL, GTL+, or LVCMOS1.8/2.5.
Virtex-II Pro Only
For Virtex-II Pro devices, all JTAG pins do not have clamp diodes, and the TDO is open drain. For more information,
see the Virtex-II Pro/Virtex-II Pro X 3.3V I/O Design Guidelines Application Note(XAPP659).
Virtex-II/-II Pro/-4/-5/-6 and Spartan-3
For these devices, the following pins have pull-up and pull-down clamp diodes:
JTAG pins (except for Virtex-II Pro)
GCK0, GCK1, GCK2, GCK3
M0, M1, M2
CCLK
DONE
PROGRAM
TDI, TDO, TMS, TCK
DXN, DXP (Temperature-sensing diode pins)
Note: VCCINT, VCCO, GND have a protection circuit, however,it might not be an explicit diode to Vcco and GND.
Spartan -3A/-3AN/-6
These devices have no pull-up diode clamps and use a floating n-well instead.
For more information, see the Virtex-II Pro/Virtex-II Pro X 3.3V I/O Design Guidelines Application Note(XAPP659).
GMT+8, 2026-4-27 13:13 , 耗时 0.391767 秒, 22 个查询请求 , Gzip 开启.
