查看: 8203|回复: 10
[电路图] 数控电源电阻选择
发表于 2014-11-29 16:48:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
收藏收藏1 分享分享 支持支持 反对反对
沙发
 楼主| 发表于 2014-11-29 16:50:21 | 只看该作者
DAC = 0V : Vo = 1.233 * ( 2200 / 390 ) + 1.233 * ( 1 + 2200/180 ) = 6.95V + 16.303V = 23.253V
DAC = 1.233V : V0 = 1.233 * ( 1 + 2200/180 ) = 16.303V
板凳
 楼主| 发表于 2014-11-29 16:53:25 | 只看该作者
When the converter is programmed to the minimum output voltage,
the DAC output (DO) equals the reference voltage of 1.233 V (typ).
Therefore, only the feedback resistor network (R1) and (R2) determines the output voltage under these conditions.
This gives the minimum output voltage possible and can be calculated as:
The maximum output voltage is determined as the DAC output (DO) is set to 0 V:
the DAC output DO (pin 3) one-step where one step is typically 19.6 mV. ( 0..63 : 6 Bit DAC )
The DAC output pin (DO) drives an external resistor (R3) connected to the external feedback
divider. The DO output has a typical output voltage range from 0 V to Vref (1.233V). If the DO output voltage is
set to 0 V, the external resistor (R3) is more or less in parallel to the lower feedback resistor (R2) giving the
highest output voltage. Programming the DO output to Vref gives the lowest output voltage. Internally, a 6-bit DAC
is used with 64-steps and 0 as the first step. This gives a typical voltage step of 19.6 mV which is calculated as:
A voltage step on DO of 19.6mV (typ) changes the output voltage by one step and is calculated as:
The possible output voltage range is determined by selecting R1, R2 and R3.
A possible larger output voltage range gives a larger output voltage step size.
The smaller the possible output voltage range, the smaller the output voltage step size.
地板
 楼主| 发表于 2014-11-29 16:56:32 | 只看该作者
Variable Control Voltage Output Voltage Adjust
This method is accomplished by connecting a variable control voltage through a resistor, R(adjust), to J3−1.
The equations provided below calculate R2 and R(adjust) where:
For example, if VO,max= 19 V, VO,min = 17 V, V(adjust),min = 0 V, V(adjust),max = 3.3 V, and R1 = 1 MΩ,
then R2 = 72.4 kΩ, and R(adjust) = 1.65 MΩ.
When V(adjust) = 0 V then VO = 19 V. When V(adjust) = 3.3 V then VO = 17 V.
5#
发表于 2014-12-1 21:31:21 | 只看该作者
全部是English啊,数学这东西啊。得细心看才行。先保存下来先。
6#
发表于 2019-7-13 22:31:43 | 只看该作者
为什么不可以调节vref呢?
8#
发表于 2020-5-4 00:11:09 | 只看该作者
全部是English
9#
发表于 2020-6-10 08:33:19 | 只看该作者
很好的参考资料
10#
发表于 2020-6-13 03:52:55 | 只看该作者
谢谢分享计算方法。
GMT+8, 2024-9-25 02:49 , 耗时 0.139269 秒, 20 个查询请求 , Gzip 开启.
