查看: 6445|回复: 2
CH341A 编程器使用说明2019.6.11
发表于 2019-6-11 08:51:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
CH341A 编程器使用说明
(彩灯版)2019.6.11
目 录
一、CH341A编程器简介..................................................................................................................2
二、编程器硬件部分.......................................................................................................................3
1、输出电压Vout....................................................................................................................3
2、spi输出..............................................................................................................................5
3、TTL输出............................................................................................................................6
4、彩灯说明.............................................................................................................................8
5、芯片放置.............................................................................................................................9
6、通用转接板.......................................................................................................................10
7、93xx芯片的放置方式图..................................................................................................11
8、45xx芯片的放置方式......................................................................................................12
9、1.8v电平转换板...............................................................................................................13
10、bga24 8mm*6mm 4*6球阵列翻盖座.........................................................................15
11、bga24 8mm*6mm 5*5球阵列翻盖座.........................................................................17
12、qfn8 8mm*6mm 翻盖座................................................................................................18
13、qfn8 6mm*5mm 翻盖座................................................................................................19
14、qfn8转接板....................................................................................................................20
15、bga24转接板..................................................................................................................21
三、安装驱动.................................................................................................................................22
1、编程器驱动.......................................................................................................................22
2、TTL串口驱动..................................................................................................................22
四、编程器软件.............................................................................................................................23
1、AsProgrammer ..................................................................................................................23
2、ch341 usb编程器软件.....................................................................................................24
3、读写KB901x类芯片.......................................................................................................25
五、常见问题及处理方法.............................................................................................................26
1、土豪金版的软件读写32M芯片不正常.........................................................................26
2、AsProgrammer不能读写microchip的93LC46A,93LC66A ......................................26
3、1.8v转接板用了,但是读写1.8v芯片不正常..............................................................26
4、正在读写操作时,操作软件会出现读写状态灯灭掉...................................................26
5、AsProgrammer读出文件比艾科等专业编程器的小......................................................26
CH341A编程器使用说明.pdf (1.23 MB, 下载次数: 18)
板凳
发表于 2020-10-21 16:06:22 | 只看该作者
来学习一下
GMT+8, 2026-5-2 01:31 , 耗时 0.634574 秒, 21 个查询请求 , Gzip 开启.
