查看: 6038|回复: 5
有一个开源的下载型编程器BPv3
发表于 2011-6-25 08:19:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
最近找到个开源的编程器BPv3,支持类型不少,看着稀奇,收录了,以下是原文
Interfacing a new microchip can be a hassle. Breadboarding a circuit, writing code, hauling out the programmer, or maybe even prototyping a PCB. We never seem to get it right on the first try.
The ‘Bus Pirate’ is a universal bus interface that talks to most chips from a PC serial terminal, eliminating a ton of early prototyping effort when working with new or unknown chips. Many serial protocols are supported at 0-5.5volts, more can be added.
  • 1-Wire
  • I2C
  • SPI
  • JTAG
  • Asynchronous serial
  • MIDI
  • PC keyboard
  • HD44780 LCD
  • 2- and 3-wire libraries with bitwise pin control
  • Scriptable binary bitbang, 1-Wire, I2C, SPI, and UART modes
We added other stuff we need, like,
  • 0-6volt measurement probe
  • 1Hz-40MHz frequency measurement
  • 1kHz - 4MHz pulse-width modulator, frequency generator
  • On-board multi-voltage pull-up resistors
  • On-board 3.3volt and 5volt power supplies with software reset
  • Macros for common operations
  • Bus traffic sniffers (SPI, I2C)
  • A bootloader for easy firmware updates
  • Transparent USB->serial mode
  • 10Hz-1MHz SUMP compatible low-speed logic analyzer
  • AVR STK500 v2 programmer clone
  • Supported in AVRDude programmer
  • Scriptable from Perl, Python, etc.
  • Translations (currently Spanish and Italian)
Since this has been such a useful tool for us, we cleaned up the code, documented the design, and released it here with specs, schematic, and source code.
原理图,看着像是eagle画的
pcb图
还有软件
BusPirate[1].firmware.v5.10.zip (541.23 KB, 下载次数: 73)
沙发
发表于 2013-1-21 10:35:42 | 只看该作者
鸟语没学好,哈哈
板凳
发表于 2013-1-21 10:58:40 | 只看该作者
看着很不错!
地板
发表于 2013-1-21 16:35:00 | 只看该作者
这个看着不错
5#
发表于 2013-3-22 00:04:52 | 只看该作者
努力挣钱努力挣钱努力挣钱努力挣钱努力挣钱
6#
发表于 2021-2-13 12:40:44 | 只看该作者
这个看着不错
GMT+8, 2026-4-28 06:25 , 耗时 0.117032 秒, 21 个查询请求 , Gzip 开启.
