查看: 7204|回复: 2
Attiny fusebit doctor (HVSP)
发表于 2011-10-20 07:14:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Attiny fusebit doctor (HVSP) – fix fusebits
Did you make a mistake while programming fusebits, or purposely disabled reset pin (RSTDISBL) or ISP programming (SPIEN)? No need to buy or make inconvenient HV programmer only for unlock couple of Tiny AVR’s. This Attiny fusebit HV doctor will cure your tiny microcontrollers, by restoring all fusebits to factory settings – nice and easy. Supports all of the serial high voltage interface AVRs, that is 8-pins: Attiny11, Attiny12, Attiny13, Attiny15, Attiny25, Attiny45, Attiny85, and 14-pins: Attiny24, Attiny44, Attiny84.
This is very simple and cheap to make, the brain of device is an Attiny2313 uC, couple of resistors and transistors, and a 5V stabilizer. You need 12V stabilized supply for this. Repair begins after the button START is pressed. Button is active again after 250ms, so pressing it will reset device and start a new repair process.
LEDs explanation:
green on – patient successfully cured, fusebits repaired. If lockbits are enabled, just verify fusebits with factory ones – and if they ok – light up green.
red on – signature problem, can’t read, no device in socket, or no such signature in database.
green flashing – signature ok, fusebits are wrong. Lockbits enabled, chip erase permission required (read below).
red flashing – signature ok, no lockbits, but for some reason can’t write new fusebits, can’t pass verification after 10 attempts.
Device uses the High-Voltage Serial Programming (HVSP) to repair fusebits. First of all patient is switched to HV memory programming, then we read signature and check if it’s supported. Then the chip erase is performed if user allows it. Next the lockbits are read, if they not set, patient receives new fusebits, proper for readed model. After that, fusebits are verified, and if they pass the test – this is end of work. If not, doctor will repeat write-verify cycle 10 times, and give up when no success.
You can find two jumpers on board:
chip erase – permit to erase whole flash memory. If lockbits are enabled, there is no possibility to set new fusebits. And there is only one way to disable lockbits – by erasing whole flash. Jumper close – permission to erase flash
unknown signature – it happens very rare, but it happens, that uC has erased signature. Signature, calibration bytes, and other data are not permanently stored in uC structure and they can be accidentally erased due to power supply spikes during programming or power cycling. Generally signature will be read as FF FF FF, but chip will work good, flash can be readed and written. If signature will not match to one from doctor database (FF FF FF or 00 00 00 too), closing this jumper will write a universal fusebits pack which will mess oscillator options and such, but will repair functionality of reset (disable RSTDISBL) and ISP programming (enable SPIEN). Microcontroller will be possible to further repair on SPI normal programmer. DO NOT use this option with Attiny11 or Attiny15.
Fusebits: internal 4MHz clock not divided by 8. Will be good to select the “fast rising power” too.
ATTENTION! -> on 09.11.2010 i’ve released last update for this project. It wont be no longer updated, scince there is a Atmega fusebit doctor which supports attiny family too (138 chips in total). Build cost for both circuits is pretty the same, so its better to make the better one.
原理图
pcb成品
固件和原理图
avr_attiny_hvsp_fusebit_doctor.rar (122.82 KB, 下载次数: 26)
avr_attiny_hvsp_fusebit_doctor_V2.rar (6.3 KB, 下载次数: 12)
avr_attiny_hvsp_fusebit_doctor_V3.rar (131.82 KB, 下载次数: 23)
沙发
发表于 2011-10-20 13:09:36 | 只看该作者
效果图,热转印,都是你亲手制作过的?
板凳
 楼主| 发表于 2011-10-20 14:27:19 来自手机 | 只看该作者
我也想啊,我直接做来卖了,呵呵
GMT+8, 2026-4-27 09:40 , 耗时 0.146305 秒, 26 个查询请求 , Gzip 开启.
