查看: 6360|回复: 3
AVR JTAG adapter
发表于 2011-10-29 13:23:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
This is a modified version of the IsoJtagISP JTAGICE I clone by Andrew Leech. I added some additional buffering as well as some reversed polarity and input protection.
Note:
I never completely tested this design, while it was recognized by AVR Studio and did work I had some reliability problems. But these may have just as easily been caused by bad cables. Since I have an official JTAGICE mkII now I never used this device much. But it is pretty much the same as the original so it probably should work correctly.
Schematic
Note:
IC3D needs a pull-up (10k or something) on its enable input (pin 13) which is missing in the schematic.
PCB
I had the PCB made profesionally, also to get some experience with that. They turned out pretty well:
Soldered
The finished adapter:
As said earlier, a pull-up resistor was missing. I fixed this by soldering a 0603 10k resistor between pin 13 (enable of one of the buffers) and pin 14 (VCC) of the buffer IC:
Download
Here you can download the Eagle, Gerber and schematic files of the project. Credits for the original design go to Andrew Leech. You can freely use these files for non-commercial use.
jtagice.zip (213.66 KB, 下载次数: 10)
沙发
发表于 2011-10-29 19:04:24 | 只看该作者
看看
好东西!
板凳
 楼主| 发表于 2011-10-29 19:10:32 | 只看该作者
越来越多,到时候会不知道做哪个
地板
发表于 2020-8-25 20:13:38 | 只看该作者
到时候会不知道做哪个
GMT+8, 2026-4-27 09:40 , 耗时 0.118225 秒, 25 个查询请求 , Gzip 开启.
