查看: 6484|回复: 1
USBtinyISP
发表于 2011-11-24 21:18:48 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
USBtinyISP
My new pc doesn't have a parallel port anymore so I couldn’t use the AVR programmer I made before anymore. That's why I decided to build one that works on a USB port.
The design is based on the USBtinyISP design from http://www.ladyada.net/make/usbtinyisp/index.html I removed the 6p connector from the circuit because I don't use that. And I've made a new print that is single sided.
The circuit drawing:
PCB layout
Pictures:
usbtinyisp_bottom.pdf (14.94 KB, 下载次数: 4)
usbtinyisp_silk.pdf (21.19 KB, 下载次数: 4)
沙发
发表于 2013-5-16 20:54:20 | 只看该作者
英文读不太懂,翻译为中文就好了。
GMT+8, 2026-4-27 11:29 , 耗时 0.338868 秒, 22 个查询请求 , Gzip 开启.
