查看: 5327|回复: 0
Trivial LVP programmer
发表于 2011-11-26 08:47:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
This is a schematic for a trivial Tait style programmer that does low voltage programming (LVP). With a single IC and a single resistor, this is one of the most simple programmers that you'll find.
(简单来说就是低压版的pic编程器,直接提供5v供电即可)
支持以下几个
16F62X/16F81X/16F88
linux下的c源代码
picprg2.3d.tar.gz (23.97 KB, 下载次数: 3)
GMT+8, 2026-4-18 18:47 , 耗时 0.123940 秒, 25 个查询请求 , Gzip 开启.
