查看: 4521|回复: 0
Eprom programmer for parallel port
发表于 2011-12-11 08:41:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
This programmer can programming all standard 8 bit EPROMs in range from 2716 (2 KByte, 24 pin) up to 278001 (1 MByte, 32 pin). It uses standard and cheap chips, most expensive part is Textool socket. Of course it's not indispensable using especially this type of socket.
Eprprgst.zip - software for Atari ST with source.
Component list:
IC : TL 497 - 1 ; 74HC00 - 1 ; 74HC14 - 1 ; 74LS06 - 1 ; 74HC377 - 4 ; 74HC541 -1
74HC574 - 2 ; CD 4555 -1 . Total 12 IC-s.
Transistor : NPN - 6 ; PNP -11 .
You may put on this positions practically any low power silicon transistor, only polarity is important. Characteristics should be about: max. current: 100mA or more, max. voltage: 30V or more.
Examples: NPN: BC237, BC548, BC337. PNP: BC307, BC558, BC327 etc.
LED : 2 piece .
Diode : 1N4148 - 11 ; Germanium or schottky -2 .
Zener diode : 3V - 4 ; 6V8 -1 ; 14V -1 ; 22V -1 ; 26V -1 ; 33V -2 .
GMT+8, 2026-4-27 09:40 , 耗时 0.156533 秒, 22 个查询请求 , Gzip 开启.
