查看: 4648|回复: 0
Philip XA-G49系列单片机isp编程器
发表于 2012-1-7 21:29:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
INTRODUCTION
This document gives a brief list of features for the XA-G49 family of
microcontrollers with FLASH memory, and describes several ways
that the FLASH memory can be programmed.
XA-G49 FEATURES
• XA CPU
• 64 kB FLASH EPROM
• FLASH EPROM is sectored to allow the user to erase and
reprogram sectors
• 2048 bytes internal RAM
• 2 kB masked BOOTROM for In-System Programming of the
FLASH EPROM
• User callable BOOTROM subroutines for FLASH erase and
programming
• Can automatically run user program or BOOTROM program at
power-up
• Four 8-bit I/O ports
• Two full-duplex UART
• Three standard 16-bit timer/counters (Timer 0, Timer 1 and
Timer 2)
• Idle and power-down modes
• Two external interrupt inputs
• Three security bits
• Fully static operation: 0 to 30 Mhz
• Packages: 44-pin PLCC, 44-pin QFP
an716.pdf (66.54 KB, 下载次数: 0)
GMT+8, 2026-4-27 11:27 , 耗时 0.420650 秒, 26 个查询请求 , Gzip 开启.
