查看: 6303|回复: 0
Free USB Programmer Amadeus for (ds)PIC and AVR Microcontrollers
发表于 2012-1-21 17:27:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Free  USB Programmer Amadeus for (ds)PIC and AVR Microcontrollers and UPAL support
Use  latest FTDI drivers for Window 7 64-bit support
Amadeus is a MCU based ISP programmer. It can program microcontrollers from Microchip and Atmel. The USB prommer hardware has an internal 12V generation for Vpp, thus no power supply is required. Since the  programming lines are high-impendance, the programmer can stick to the target device in most cases. Although the prommer works at 5V                        (USB) in many cases it is possible to run the target at voltages  between 3.0V and 5.5V.
Highlights are a very fast ATmega, PIC18, PIC24, dsPIC30, PIC32 and dsPIC33  programming. It is possible to use the programming pins of your MCU to trace the program flow. An integrated relay offers the possibility to switch the target's power supply for programming  and reset purposes. The programmer firmware can be programmed by  the included USB controller, thus no other programmer is needed  for first use!
The  open algorithm interface UPAL, gives everybody the opportunity to write his/her own programming  algorithms.
More then 350 supported microcontrollers
AVR ATmega
ATmega48, ATmega8, ATmega88, ATmega8515, ATmega8535, ATmega16, ATmega162, ATmega164P(V), ATmega168, ATmega169, ATmega32, ATmega324P(V), ATmega325, ATmega3250, ATmega329, ATmega3290, Atmega64 3,1s@16Mhz, Atmega640(V), ATmega644(V) 3,4s@16MHz, ATmega644P(V), ATmega645, ATmega6450, ATmega649,  ATmega6490, ATmega128,  ATmega1280(V), Atmega1281(V) (33)
AVR  ATtiny
ATtiny11, ATtiny12 2,8s,(Special User-Interface)ATtiny13(V), ATtiny2313 0,7s, ATtiny24 0,6s,ATtiny25, ATtiny26(L), ATtiny261, ATtiny44, ATtiny45, ATtiny461,ATtiny84, ATtiny85, ATtiny861 (16)
PIC10
PIC10F200, PIC10F202, PIC10F204, PIC10F206    0,8s (4)
PIC12/PIC16 (UPAL  available)
PIC12F629, PIC12F675 2,3s, PIC16F630 2,3s, PIC16F676 (4)
PIC18
PIC18Fxx2, PIC18Fxx8:
PIC18F242 1,9s, PIC18F248, PIC18F252 2,4s, PIC18F258, PIC18F442 1,9s, PIC18F448, PIC18F452, PIC18F458 (4)
PIC18Fx220, PIC18Fx320:
PIC18F1220, PIC18F2220, PIC18F4220, PIC18F1320 1,7s, PIC18F2320, PIC18F4320 (6)
PIC18Fx331, PIC18Fx431:
PIC18F2331, PIC18F2431, PIC18F4331, PIC18F4431 2s (4)
PIC18F2xx0, PIC18F2x21, PIC18F2xx5, PIC18F4xx0, PIC18F4x21, PIC18F4xx5:
PIC18F2221, PIC18F2321, PIC18F2410, PIC18F2420, PIC18F2455, PIC18F2480, PIC18F2510, PIC18F2515, PIC18F2520, PIC18F2525, PIC18F2550, PIC18F2580, PIC18F2585, PIC18F2610, PIC18F2620, PIC18F2680, PIC18F4221, PIC18F4321, PIC18F4410, PIC18F4420, PIC18F4455, PIC18F4480, PIC18F4510, PIC18F4515, PIC18F4520, PIC18F4525, PIC18F4550 2s, PIC18F4580, PIC18F4585, PIC18F4610, PIC18F4620, PIC18F4680 (32)
PIC18Fx310, PIC18Fx410, PIC18Fx390, PIC18Fx490:
PIC18F6310, PIC18F6390, PIC18F6410, PIC18F6490, PIC18F8310, PIC18F8390, PIC18F8410, PIC18F8490 4s (8)
PIC18F6x20, PIC18F8x20:
PIC18F6520, PIC18F6620, PIC18F6720 6s, PIC18F8520, PIC18F8620 4,4s, PIC18F8720 6s (6)
PIC18F6x2x, PIC18F8x2x:
PIC18F6525, PIC18F6621, PIC18F8525, PIC18F8621 3,2s (4)
PIC18F6x22, PIC18F6x27,PIC18F8x22, PIC18F8x27:
PIC18F6527, PIC18F6622, PIC18F6627, PIC18F6722 5s, PIC18F8527, PIC18F8622, PIC18F8627, PIC18F8722 5s (8)
PIC18Fxx80, PIC18Fxx85:
PIC18F6585, PIC18F6680, PIC18F8585, PIC18F8680 3,2s (4)
PIC18FJ* (UPAL based)
PIC18F45J10 Family:
PIC18F24J10, PIC18F25J10 2,7s, PIC18F44J10, PIC18F45J10, PIC18LF24J10, PIC18LF25J10, PIC18LF44J10, PIC18LF45J10 (8)
PIC18F6xJxx, PIC18F8xJxx:
PIC18F63J11, PIC18F63J90, PIC18F64J11, PIC18F64J90, PIC18F65J10, PIC18F65J11, PIC18F65J15, PIC18F65J50, PIC18F65J90, PIC18F66J10, PIC18F66J11, PIC18F66J15, PIC18F66J16, PIC18F66J50, PIC18F66J55, PIC18F67J10 9,2s, PIC18F67J11, PIC18F67J50, PIC18F83J11, PIC18F83J90, PIC18F84J11, PIC18F84J90, PIC18F85J10, PIC18F85J11, PIC18F85J15, PIC18F85J50, PIC18F85J90, PIC18F86J10, PIC18F86J11, PIC18F86J15, PIC18F86J16, PIC18F86J50, PIC18F86J55, PIC18F87J10, PIC18F87J11, PIC18F87J50 (36)
PIC18F95J60 Family:
PIC18F66J60, PIC18F66J65, PIC18F67J60, PIC18F86J60, PIC18F86J65, PIC18F87J60, PIC18F96J60, PIC18F96J65, PIC18F97J60 9,2 (9)
PIC24FJ* (UPAL based) PIC24FJXXXGA0XX Programming Specification
PIC24FJ16GA002, PIC24FJ16GA004 1,4s, PIC24FJ32GA002, PIC24FJ32GA004, PIC24FJ48GA002, PIC24FJ48GA004, PIC24FJ64GA002, PIC24FJ64GA004 4,3s, PIC24FJ64GA006, PIC24FJ64GA008, PIC24FJ64GA010, PIC24FJ64GB106, PIC24FJ64GB108, PIC24FJ64GB110, PIC24FJ96GA006, PIC24FJ96GA008, PIC24FJ96GA010, PIC24FJ128GA006, PIC24FJ128GA008, PIC24FJ128GA010, PIC24FJ128GA106, PIC24FJ128GB106, PIC24FJ128GA108, PIC24FJ128GB108, PIC24FJ128GA110, PIC24FJ128GB110, PIC24FJ192GA106, PIC24FJ192GB106, PIC24FJ192GA108, PIC24FJ192GB108, PIC24FJ192GA110, PIC24FJ192GB110, PIC24FJ256GA106, PIC24FJ256GB106, PIC24FJ256GA108, PIC24FJ256GB108, PIC24FJ256GA110, PIC24FJ256GB110 (38)
PIC24HJ* (UPAL based)
PIC24HJ12GP201, PIC24HJ12GP202, PIC24HJ16GP304, PIC24HJ32GP202, PIC24HJ32GP204, PIC24HJ32GP302, PIC24HJ32GP304, PIC24HJ64GP202, PIC24HJ64GP204, PIC24HJ64GP206 4,3s, PIC24HJ64GP210, PIC24HJ64GP502, PIC24HJ64GP504, PIC24HJ64GP506, PIC24HJ64GP510, PIC24HJ128GP202, PIC24HJ128GP204, PIC24HJ128GP206, PIC24HJ128GP210, PIC24HJ128GP306, PIC24HJ128GP310, PIC24HJ128GP502, PIC24HJ128GP504, PIC24HJ128GP506, PIC24HJ128GP510, PIC24HJ256GP206 15s, PIC24HJ256GP210, PIC24HJ256GP610 (28)
dsPIC30
dsPIC30F2010 1,3s, dsPIC30F2011, dsPIC30F2012, dsPIC30F3010, dsPIC30F3011, dsPIC30F3012, dsPIC30F3013, dsPIC30F3014, dsPIC30F4011, dsPIC30F4012, dsPIC30F4013, dsPIC30F5011, dsPIC30F5013, dsPIC30F5015, dsPIC30F5016, dsPIC30F6010, dsPIC30F6010A, dsPIC30F6011, dsPIC30F6011A, dsPIC30F6012, dsPIC30F6012A, dsPIC30F6013, dsPIC30F6013A, dsPIC30F6014 12,5s, dsPIC30F6014A, dsPIC30F6015 (26)
PIC32* (UPAL based)
PIC32MX320F032H, PIC32MX320F064H, PIC32MX320F128H, PIC32MX320F128L, PIC32MX340F128H, PIC32MX340F128L, PIC32MX340F256H, PIC32MX340F512H, PIC32MX360F256L, PIC32MX360F512L 12,3s / 16,8s, PIC32MX420F032H, PIC32MX440F128H, PIC32MX440F128L, PIC32MX440F256H, PIC32MX440F512H, PIC32MX460F256L, PIC32MX460F512L 12,3s / 16,8s (17)
Info: JTAG / ICSP; if a checksum comparison for verification is enough, the programming times are about 60% of the given times.
dsPIC33* (UPAL based)
dsPIC33FJ06GS101, dsPIC33FJ06GS102, dsPIC33FJ06GS202, dsPIC33FJ12GP201, dsPIC33FJ12GP202, dsPIC33FJ12MC201, dsPIC33FJ12MC202, dsPIC33FJ16GP304, dsPIC33FJ16GS402, dsPIC33FJ16GS404, dsPIC33FJ16GS502, dsPIC33FJ16GS504, dsPIC33FJ16MC304, dsPIC33FJ32GP202, dsPIC33FJ32GP204, dsPIC33FJ32GP302, dsPIC33FJ32GP304, dsPIC33FJ32MC202, dsPIC33FJ32MC204, dsPIC33FJ32MC302, dsPIC33FJ32MC304, dsPIC33FJ64GP202, dsPIC33FJ64GP204, dsPIC33FJ64GP206, dsPIC33FJ64GP306, dsPIC33FJ64GP310, dsPIC33FJ64GP706, dsPIC33FJ64GP708, dsPIC33FJ64GP710, dsPIC33FJ64GP802, dsPIC33FJ64GP804, dsPIC33FJ64MC202, dsPIC33FJ64MC204, dsPIC33FJ64MC506, dsPIC33FJ64MC508, dsPIC33FJ64MC510, dsPIC33FJ64MC706, dsPIC33FJ64MC710, dsPIC33FJ64MC802, dsPIC33FJ64MC804, dsPIC33FJ128GP202, dsPIC33FJ128GP204, dsPIC33FJ128GP206, dsPIC33FJ128GP306, dsPIC33FJ128GP310, dsPIC33FJ128GP706, dsPIC33FJ128GP708, dsPIC33FJ128GP710, dsPIC33FJ128GP802, dsPIC33FJ128GP804, dsPIC33FJ128MC202, dsPIC33FJ128MC204, dsPIC33FJ128MC506, dsPIC33FJ128MC510, dsPIC33FJ128MC706, dsPIC33FJ128MC708, dsPIC33FJ128MC710, dsPIC33FJ128MC802, dsPIC33FJ128MC804, dsPIC33FJ256GP506 15s, dsPIC33FJ256GP510, dsPIC33FJ256GP710, dsPIC33FJ256MC510, dsPIC33FJ256MC710 (64)
Calibration value preservation is not supported for devices written in red!
Das Sichern von Kalibrierungswerten wird bei den rot geschriebenen Controllern nicht unterstützt!
Tested / Getestet
Not Tested / Nicht getestet
Estimated programming and verification duration w/o EEPROM when the program uses the complete flash memory.
Ungef?hre Programmierzeit mit Vergleich ohne EEPROM, wenn das Program den gesamten Flashspeicher belegt.
* PIC18FJ, PIC24, PIC32 and dsPIC33 might need a level-converter for 3V! See documentation.
* PIC18FJ, PIC24, PIC32 und dsPIC33 ben?tigen m?glicherweise einen Pegelwander für 3V! Sieht Dokumentation.
制作文档,包含原理图,软件使用
Documentation.zip (1.75 MB, 下载次数: 4)
软件,安装后里面有固件
Software.exe (460.88 KB, 下载次数: 4)
eagle格式原理、pcb图
Layout.zip (103.27 KB, 下载次数: 1)
Parallel                                high-voltage interface for ATmega reanimation
HVSchematics.pdf (43.86 KB, 下载次数: 2)
HVAdapter.zip (16.95 KB, 下载次数: 4)
Trace Macros
PIC18.zip (132.13 KB, 下载次数: 2)
dsPIC30.zip (135.61 KB, 下载次数: 2)
GMT+8, 2026-4-18 20:26 , 耗时 0.162299 秒, 26 个查询请求 , Gzip 开启.
