查看: 5890|回复: 1
Parallel Port Eprom Programmer
发表于 2011-4-15 07:58:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
并口编程器,在linux下开发的,开源,下面是英文原文
PPEP has several components:
hardware The hardware board that you plug on the PC parallel port.
  This is a double sided board with a few TTL chips, a TL 497
  and a 28-pins programming slot.  The hardware supports only
  one programming voltage (either 12.5 or 12.75).  It can
  program a 2764/27C64, 27128/27C128 or 27256/27C256.
drivers  A GNU/Linux driver that is loaded in the kernel and which
  controls the hardware through the parallel port.  More
  drivers may be added in the future.  The Linux driver
  is written in C.
tools  A tool that allows programming/reading the eproms supported
  by the hardware.  The tools are written in ADA.  They must
  be compiled with GNAT.
To build the drivers and the tools, you must do the following:
  1/ Run the configure script:
./configure
     This will configure 'make.defs' and setup the path of you Linux includes
     Verify the flags that are used for building the driver and
     make sure they are compatible or the same as the ones used
     when building your kernel.
     Note: The path of Linux includes is hard-coded to /usr/src/linux/include
  2/ Build everything with make:
make
To install the driver do:
  1/ Log as root
  2/ Copy the PPEP module in /lib/modules/<kernel>chars
cp drivers/linux/ppep /lib/modules/2.2.19/chars/ppep
  3/ Update the module dependencies using depmod
/sbin/depmod
  4/ Create the ppep devices using mknod
     This step is necessary only for Linux 2.2.  It is not necessary for
     Linux 2.4
mknod /dev/ppep0 c 120 0
  5/ You can also load the module
/sbin/insmod ppep
To read a 27128 eprom:
   epprg -r file.bin -t 27128
   the file 'file.bin' will contain the binary dump of the 27128 eprom.
To write a 2764 eprom:
   epprg -w file.bin -t 2764
I've tested PPEP hardware, driver and tools on a Linux 2.2.17, 2.2.19
and 2.4.8 kernel with the following eproms:
2764A-2  Intel Vpp 12.5V
27128-25  Vpp 12.5V
27256-1   Vpp 12.5V
27256-2   Vpp 12.5V
27256-25  Vpp 12.5V
全部工程文件
ppep-0.2.tar[1].gz (329.8 KB, 下载次数: 9)
│  ChangeLog
│  configure
│  configure.in
│  COPYING
│  install-sh
│  make.defs.in
│  Makefile
│  README
├─drivers
│  │  Makefile
│  ├─linux-2.2
│  │      Makefile
│  │      ppep.c
│  └─linux-2.4
│          Makefile
│          ppep
│          ppep.c
├─hardware
│      ppep-bot.pdf
│      ppep-bot.ps
│      ppep-parts.txt
│      ppep-top.pdf
│      ppep-top.ps
│      ppep.brd
│      ppep.sch
│      README
│      schema.pdf
├─include
│  └─linux
│          ppep.h
└─tools
        eppp-buffer.adb
        eppp-buffer.ads
        eppp-driver.adb
        eppp-driver.ads
        eppp-file.adb
        eppp-file.ads
        eppp-tool-version.ads
        eppp-tool-version.tmpl
        eppp-tool.adb
        eppp-tool.ads
        eppp.ads
        epprg.adb
        Makefile
沙发
发表于 2021-3-20 13:48:35 | 只看该作者
谢谢啦,理解了
GMT+8, 2026-4-28 06:35 , 耗时 0.113039 秒, 20 个查询请求 , Gzip 开启.
