查看: 5189|回复: 0
Tait Classic PIC Programmer
发表于 2012-2-27 18:03:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Tait Classic PIC Programmer - (c) David Tait
Description
The Tait Classic PIC Programmer was designed by David Tait. It is a High-Voltage Programmer which is connected to the PC via the parallel port (LPT port).
Schematics / Layouts
Supported PICs
This programmer supports all PICs which can be programmed in High-Voltage mode. For a list of all PICs supported by PICPgm Software can be found here.
GMT+8, 2026-4-27 09:40 , 耗时 0.328373 秒, 22 个查询请求 , Gzip 开启.
