查看: 4739|回复: 0
El Cheapo PICmicro Programmer
发表于 2012-2-27 18:29:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
原理图
For different PICMicro Pinouts, the pins to connect (with sample        parts) are:
Signal
8-Pin
14-Pin
18-Pin
28-Pin
40-Pin
12C5XX
16C505
16F84
16C73
16C74
Vcc
1
1
15
20
11,32
Gnd
8
14
5
8,19
12,31
_MCLR
4
4
4
1
1
Data
7
13
13
28
40
Clock
6
12
12
27
39
Parts list for the "Version    3.10" Programmer
Bill of Materials
Part        Number
        R1
        R2-R5
        R3-R4
        C1
        C2, C4
        C3
        CR1
        CR2, CR3
        Q1
        Q2
        U1
        U2
        CR1
        J1
        J2
Value/Comments
        220 Ohms 1/4 Watt
        10K 10K Ohms 1/4 Watt
        1K Ohms 1/4 Watt
        10 uF 25 Volt Electrolytic
        0.1 uF 35 Volt Tantalum
        0.01 uF Ceramic
        5.1 Volt 1 Watt Zener
        IN914 Silicon Diode
        2N7000 NMOS FET
        2106a PMOS FET
        78L12 Voltage Regulator
        18 Pin IC Socket
        5.12 V/1 Watt Zener Diode
        2.5 mm Power Plug
        DB-25F Solder Cup Connector
        "Wall Wart", 14+ Volts Supply with2.5 mm Power Plug
        Prototyping Card/Breadboard
        6'  "Straight Through" DB-25M to DB-25F
Digi-Key        Part Number
220QBK-ND
        10KQBK-ND
        1.0KQBK-ND
        P6248-ND
        P2053-ND
        P4922-ND
        1N4733AMSCT-ND
        1N4148DICT-ND
        2N7000P-ND
        ZVP2106A-ND
        LM78L12ACZ-ND
        A9318-ND
        CP-202B-ND
        125F-ND
        AE1012-ND
软件和调试工具
elcheapo.zip (98.36 KB, 下载次数: 0)
GMT+8, 2026-4-27 11:27 , 耗时 0.123922 秒, 26 个查询请求 , Gzip 开启.
