查看: 4905|回复: 0
Wisp628 pic编程器
发表于 2012-5-15 19:44:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
wisp pic编程器的升级版
支持芯片:
12F629, 12F675
16F627(A), 16F628(A)
16F630, 16F648A, 16F676
16F72, 16F73, 16F74, 16F76, 16F77
[16F737, 16F747, 16F767, 16F777]
16F818, 16F819
[16F83], 16C84, 16F84(A)
16F870, 16F871, 16F872, 16F873(A), 16F874(A), 16F876(A), 16F877(A)
[16F87], 16F88
18F1220,  18F1320, 18F2220, [18F2320]
18F242, [18F2439], 18F248, 18F252, [18F2539], 18F258
18F4220, 18F4320
18F442, 18F4439, 18F448, 18F452, [18F4539], 18F458
[18F6520, 18F6525, 18F6585, 18F6620, 18F6720]
[18F8520, 18F8525, 18F8585, 18F8620, 18F8621, 1F8680, 18F8720]
db15对应芯片接线
                             The table below shows how the Wisp628 programmer must be connected toa target PICmicro controller.
D15 pintarget connectionrecommended
wire color
8-pin PICmicro's18-pin PICmicro's                              28-pin PICmicro's40-pin PICmicro's
12F62912F67516C8416F84(A)16F62716F62816F7316F7616F87016F87216F87316F873A16F87616F876A18F24218F24818F25218F25816F7416F7716F87116F87416F874A16F87718F44218F44818F45218F458
1Gnd
(ground, VSS)
black858, 1912, 31
2Vcc
(power, VDD)
red1142011, 32
3RB6 (ICSPCK) purple (used to be green, as all pictures still show)6122739
4RB7 (ICSPDAT)blue7132840
5/MCLRyellow4411
6LVP (PGM)white-102436
7asynch Wisp628 ==> target-71826
8asynch Wisp628 <== target-81725
GMT+8, 2026-4-27 15:02 , 耗时 0.178861 秒, 26 个查询请求 , Gzip 开启.
