查看: 5273|回复: 2
ISP Programmer并口下载线
发表于 2012-5-27 16:00:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
并口对应需编程的isp单片机接法
  Microcontroller  LPT port   LPT port
  signal           signal     pin number
[STROBE]  ----   STROBE     1
RESET     ----   AUTOLF     14
MOSI      ----   INIT       16
SCK       ----   SLCT-IN    17
MISO      ----   ACK        10
GND       ----   GND        25
支持芯片
  • AT89S2051, AT89S4051, AT89S51, AT89LS51, AT89S52, AT89LS52, AT89S53, AT89S8252, AT89S8253
  • AT90S1200, AT90S2313, AT90S2323, AT90S2333, AT90S2343, AT90S4414, AT90S4433, AT90S4434, AT90S8515, AT90S8535, AT90CAN32, AT90CAN64, AT90CAN128, AT90PWM2, AT90PWM3, AT90USB646, AT90USB647, AT90USB82, AT90USB162, AT90USB1286, AT90USB1287
  • ATtiny12, ATtiny13, ATtiny15, ATtiny24, ATtiny25, ATtiny26, ATtiny44, ATtiny45, ATtiny84, ATtiny85, ATtiny261, ATtiny461, ATtiny861, ATtiny2313
  • ATmega48, ATmega48P, ATmega8, ATmega88, ATmega88P, ATmega8515, ATmega8535, ATmega16, ATmega161, ATmega162, ATmega163, ATmega164P, ATmega165P, ATmega168, ATmega168P, ATmega169, ATmega32, ATmega323, ATmega324P, ATmega325, ATmega328P, ATmega329, ATmega64, ATmega128, ATmega640, ATmega644, ATmega644P, ATmega645, ATmega649, ATmega1280, ATmega1281, ATmega1284P, ATmega2560, ATmega2561, ATmega3250, ATmega3290, ATmega6450, ATmega6490
Supported serial Flash memories:
  • AT45DB011B, AT45DB011D, AT45DB021B, AT45DB021D, AT45DB041B, AT45DB041D, AT45DB081B, AT45DB081D, AT45DB161B, AT45DB161D, AT45DB321B, AT45DB321C, AT45DB321D, AT45DB642D, AT45CS1282
  • AT25DF021, AT25DF041A, AT25DF081, AT26DF081, AT25DF161, AT26DF161, AT25DF321, AT25DF641, AT25F512B, AT25FS010, AT26F004
软件支持win7
ispprog_setup_1.2.0.56.exe (568.92 KB, 下载次数: 13)
沙发
发表于 2012-5-31 21:51:38 | 只看该作者
看样子不错啊,支持的芯片不算少.做个试试
板凳
发表于 2012-6-4 22:38:36 | 只看该作者
好贴阿楼主,代表大家谢谢您
GMT+8, 2026-4-27 11:29 , 耗时 0.285217 秒, 25 个查询请求 , Gzip 开启.
