查看: 10184|回复: 10
mini universal programmer
发表于 2012-9-6 19:28:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
评分
参与人数 1专家 +1 银子 +3 收起 理由
liyf + 1 + 3 赞一个!
查看全部评分
沙发
发表于 2012-10-9 17:59:05 | 只看该作者
the design is pdiusbd12+51+fpga,and two power
板凳
 楼主| 发表于 2012-10-9 18:23:06 | 只看该作者
this programmer pcb is simple but very good support chip
地板
 楼主| 发表于 2012-10-9 18:25:16 | 只看该作者
Supports Over 7000 Common Microcontrollers , CPLD , FPGA , EPROM , EEPROM ,FLASH,GAL,NAND
40 Pin ZIF SOCKET
ISP Cable For ATMEL 89S5X, AVR, PIC
JTAG Cable For Xilinx FPGA and CPLD , ALTERA CPLD and FPGA
JAM and SVF Player For Programming JTAG Devices
Digital IC Tester For 7000/4000/SRAM
USB Powered (No Need For External Supply)
User Friendly Software For Win98/Me/XP/2000 Windows7 (32-64)،VISTA
Automatic Device Identification & Device Insertion Notification
Very Small and Portable
Lifetime Software Upgrade
Supports Intel Hex - bin - Svf - Xilinx Jed & bit Files
3.0V-6.5V Device Support - VPP form 0V - 25V
Fast USB Interface
Gang Option
Digital IC Tester
5#
发表于 2012-10-9 20:23:36 | 只看该作者
40 Pin ZI ...
you have schematic ?
6#
 楼主| 发表于 2012-10-9 21:44:47 | 只看该作者
sorry not have
7#
 楼主| 发表于 2012-10-10 16:58:11 | 只看该作者
you see programmer board same as this programmer
8#
发表于 2013-2-27 23:36:12 | 只看该作者
Please upload TNM5000 programmer  (PICTURE)
9#
发表于 2013-2-28 10:03:00 | 只看该作者
we need the sch for the programmer.
10#
发表于 2013-9-10 02:32:31 | 只看该作者
Thank you for sharing!
GMT+8, 2026-4-27 13:20 , 耗时 0.107908 秒, 23 个查询请求 , Gzip 开启.
