查看: 4810|回复: 1
TI原厂的CC Debug
发表于 2013-2-8 10:25:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The CC Debugger can be used to debug and program the flash of any of the RF System-on-Chip
(SoC) devices from Texas Instruments (except the CC1010). The PC Tools available for these
purposes are the SmartRF Flash Programmer from Texas Instruments and IAR Embedded
Workbench for 8051 from IAR Systems.
It is also possible to control and run tests on the devices from SmartRF Studio. When using SmartRF
Studio, the debugger supports the CC2520 transceiver in addition to the SoC devices.
硬件内部图
手册中的原理图
CC_Debugger_User\'s_Guide.pdf (1.21 MB, 下载次数: 0)
沙发
发表于 2013-8-14 16:36:46 | 只看该作者
好像有诶 很便宜的
GMT+8, 2026-4-27 11:29 , 耗时 0.101779 秒, 22 个查询请求 , Gzip 开启.
