查看: 5341|回复: 1
[艾科beeprog] Adapter DIL48/SDIP52 SDA545xOTP
发表于 2013-9-15 09:07:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Adapter DIL48/SDIP52 SDA545xOTP (wiring)
Assigned for device(s): Siemens SDA545xOTP in shrink-DIP52 package
Usable for programmer(s): LabProg-48LV, LabProg+
Wiring description.
DIL48  SDIP52       Pin name      Note
   4       1         PMSEL1
  12       2         DATA D7
  11       3         DATA D6
  10       4         DATA D5
   9       5         DATA D4
   8       6         DATA D3
   7       7         DATA D2
   6       8         DATA D1
   5       9         DATA D0
  16      11         VDD (VCCP)
  17      14         PALE
  18      15         RST\
19      24         VSSA (GND)
  20      26         PSEN\
  21      23         A0/A8
  22      22         A1/A9
  23      21         A2/A10
  24      10         VSS (GND)
  25      20         A3/A11
  26      19         A4/A12
  27      18         A5/A13
  28      17         A6/A14
  29      16         A7/A15
  30      28         VDDA (VCCP)
  34      35         VSS (GND)
  35      36         PRD\
  36      37         VDD (VCCP)
  37      38         EA\/VPPpixel
  38      39         EA\/VPPprogr
  39      44         PSEL\
  40      46         PROG\
  41      52         PMSEL0
          29         IREF          connect through 27 kOhm resistor to                                     SDIP52/28
          12         XTAL1         connect C=33pF to  24/DIL48
          13         XTAL2         connect C=33pF to  24/DIL48                                   Connect Xtal 6MHz between pins                                     XTAL1 and XTAL2.
Note: - see at Siemens about original material "SDA 545XOTP, Programming Manual"
收藏收藏1 分享分享 支持支持 反对反对
沙发
发表于 2020-8-30 02:12:53 | 只看该作者
谢谢分享引脚关联表。
GMT+8, 2026-4-18 13:34 , 耗时 0.117250 秒, 18 个查询请求 , Gzip 开启.
