查看: 6843|回复: 1
[河洛HILO] ADP-PZ5128
发表于 2014-5-11 08:52:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
ADP-PZ5128
for Philips PZ3064-/CS/NS, PZ5064-/CS/NS, PZ3128-/CS/NS, PZ5128-/CS/NS
and Xilinx XCR3064, XCR5064, XCR3064A, XCR5064C, XCR5128, XCR3128, XCR5128C, XCR3128A
ALL07 knows all of them (executable is Apz5032.exe), however to program Xilinx one have to select the
matching Philips type (the DIE is the same).
Adapter is NOT supported by ALL03 at all, however one might use pinout from this Adapters e.g. PQ100
CPLDs and wire it to PLCC84 Adapter (to ADP-PZ5064).
This Adapter is necessary to program CPLDs with locked ISP/JTAG pins, so not a simple ISP Adapter.
Schematic contains pinout for PQ100, VQ100, TQ100, TQ128 and PQ160 packages.
Note: due bonding differences Adapter for PQ100 need a jumper to select type, where others not.
HiLo_ADP-PZ5128.PDF (257.46 KB, 下载次数: 5)
相关帖子
沙发
发表于 2020-8-24 10:14:26 | 只看该作者
谢谢分享河洛皮底爱抚。
谢谢楼主给俺留着沙发。
GMT+8, 2026-4-18 13:34 , 耗时 0.215781 秒, 25 个查询请求 , Gzip 开启.
