查看: 6108|回复: 3
[电路图] Control an LM317T with a PWM signal
发表于 2014-11-28 09:09:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The LM317T from National Semiconductor is a popular adjustable-voltage regulator that provides output voltages of 1.25 to 37V with maximum 1.5A current. You can adjust the output voltage with a potentiometer. The circuit inFigure 1 replaces the potentiometer with an analog voltage that you can control from a PWM (pulse-width-modulation) signal. You control this signal with a microcontroller or any other digital circuit. You can use the same microcontroller to dynamically monitor the output and adjust the LM317T.
Using an RC lowpass filter and an op amp, you can convert the PWM signal to a dc level that can adjust the LM317T’s voltage output. Varying the pulse width of the input signal lets you generate an analog voltage of 0 to 5V at the output of the lowpass filter. The op amp multiplies the voltage to achieve the desired voltage range.
For scenarios in which you must multiply the input voltage by two, the LM317T’s adjustment pin receives 0 to 10V. Its output-voltage range is 1.25 to 11.25V. The equation VOUT=VADJ+1.25V governs the LM3175T’s output voltage. You can change the op amp’s gain by choosing proper values for R4 and R2. You must be able to remove offset voltages from the op amp. Use an op amp, such as a National Semiconductor LM741, with null adjustment. The selection of values for the capacitor and resistor for the RC lowpass filter depends on the PWM signal’s frequency. This circuit uses values for a 1-kHz PWM signal.
You can improve the circuit by replacing the RC lowpass filter with an active filter and then feeding a feedback signal from the circuit’s output into the microcontroller for dynamic adjustments.
收藏收藏1 分享分享 支持支持 反对反对
沙发
 楼主| 发表于 2014-11-28 09:10:12 | 只看该作者
板凳
发表于 2014-11-28 20:07:22 | 只看该作者
这个做数控电压比较稳定,可以用pwm,dac等控制
地板
发表于 2020-5-3 21:51:23 | 只看该作者
学习了 感谢
GMT+8, 2026-4-28 03:44 , 耗时 0.529714 秒, 20 个查询请求 , Gzip 开启.
